'61 door panels ???? - NCRS Discussion Boards
  • Las K.
    • July 31, 2006
    • 96
    I'm ready to install a complete set of Al Knock door panels and can't remember how many screws are used to hold them in place. Not concerned with the bottom portion, but don't want to mess up on the SST inserts. can anyone help with these locations. Thanks
  • Mike M.
    • May 31, 1974
    • 8396
    Re: '61 door panels ????
    look on the back side of the cardboard door panels. you should be able to see the pre-punched holes in the cardboard underneath the vinyl that is folded over the cardboard.mike
    • Las K.
      • July 31, 2006
      • 96
      Mike, I count 10 holes and am concerned with the top portion of the panels. Do I use the 2 holes at the top corners; and do I use the recess ferrels in all of the locations or only at the SST portions?
