AC Delco Plugs... R43 or R45??? - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2655
    Since you can no longer buy AC Delco R44 plugs, at least I could not locate any locally here in Omaha, NE.; which plug would be a better choice between an R43 which is one heat range colder than the standard R44 or an R45 which is one heat range hotter? This is for a 1965 Corvette equipped with 327/350 engine and will be driven to and from NCRS events and around town.
    James West
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    R45 *NM*
    • Denny J.
      • November 1, 2000
      • 244
      Re: AC Delco Plugs... R43 or R45???
      go to ebay put in "ac delco acniter"
      • Bruce B.
        • May 31, 1996
        • 2930
        LAST YEAR I PUT A SET OF R45 PLUGS IN MY 62 CORVETTE 340 HP. IT IS A HIGH COMPRESSION ENGINE (11.25 TO 1)AND IT HAS NEVER RUN BETTER. THE CORRECT STOCK PLUG IS A 44 OR A 45 FOR CITY DRIVING. THE R45 PLUGS ARE AVAILABLE AT MOST AUTO STORES FOR ABOUT $1.30 PER PLUG.
        YOU CAN FIND NEW 44 PLUGS ON EBAY BUT YOU WILL PROBABLY PAY $5.00 OR MORE PER PLUG PLUS SHIPPING.
          • 15677
          Please turn off caps, and...
          ...if you want to use an OE type non-resistor plug as was used up to circa 1969 the NGK B4 and Denso W14-U are non-resitor equivalents to the discontinued non-resistor AC 45. They both also have a more corrosion resistant shell than the black oxide finish on ACs, but will loose more points than ACs if you have your car judged.
          • James W.
            • December 1, 1990
            • 2655
            Thanks to all Who Responded!!! *NM*
            • Dave Suesz
              There's always
              eBay
              eBay item
