c-1 rpo brake shoes - NCRS Discussion Boards
c-1 rpo brake shoes
  • Mike M.
    • May 31, 1974
    • 8385
    c-1 rpo brake shoes
    anyone help me identifying these nos sintered metallic brake shoes? they have stamped #'s and ink stamped #'s. stamped steel #'s are 5461965 and 54603?8. rivit going thru the ? makes for difficulty in identifying the # but is suspect its either and 8 or 9 where the ? marks are in above stampings. the ink stampings are 5460382 and 5460381. one set is 2" wide with riveted pucks and the other set is 1 3/4" wide , aslo with riveted pucks. thanks guys. mike
  • Joseph S.
    National Judging Chairman
    • March 1, 1985
    • 872
    Re: c-1 rpo brake shoes
    Mike, I have a set of those brakes! I was told they were 63-4 J56 Metallic Brake shoes. They fit into the same size drum as the base brake shoes. No cooling fins but different surface finish. Not to be confused with the big Z06 pieces!! There were about 5000 63's built with those brakes!
    BUT! I could be all wrong about this!
    Joe
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Nash Metropoliton *NM*
      • Mike M.
        • May 31, 1974
        • 8385
        Re: Nash Metropoliton
        smart-ass response from new XKE owner typical british response. bet the ignition on the nash metro will prove more reliable than the Lucas crap on the jag. mikie
          • 15674
          Original and GMPD service C2 J-65 friction material segments are "bonded", which I think means "welded" to the shoe, so if these are riveted...
          • Dick W.
            • 10483
            Lucas electics by Dr. Lucas, the Prince of Darkness. The way you tell if a British car has oil in it? If it quits leaking you need to add oil
            Dick Whittington
            • Jean C.
              • June 30, 2003
              • 688
              Dickie, know why Brits drink warm beer? Because Lucas made the fridges.
              • Dick W.
                • 10483
                You know why they still make British cars? So the world can get even with Doctors and Lawyers
                'Nuff on British cars. Back to Corvettes
                Dick Whittington
                • Verle R.
                  • March 1, 1989
                  • 1163
                  Jaguar
                  Only the British would name such a dog after a cat.
                  Verle
