C-1 1959 Lower Radiator Hose - NCRS Discussion Boards
  • Jimmy J.
    • May 31, 1988
    • 304
    What is the purpose of the spring or wire coil in the botton radiator hose and what area of the hose should it be in? Thanks, Jimmy
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: C-1 1959 Lower Radiator Hose
    Keeps it from possibly collasping. Should be between end of water pump and end of radiator, especially the bend.
      50's-60's hose material needed the spring to prevent collapse at highway rpm; today's hoses (including most repros) are much stronger and don't require the spring.
