63 Fuelie options - NCRS Discussion Boards
63 Fuelie options
  • Howard Cox
    63 Fuelie options
    What posi gear ratios were available for a 63 FI car with a wide ratio T-10 tranny?
    Were power windows available on the same car?
    Thanks for thr responses in advance!
  • Bill Lynch
    Re: 63 Fuelie options
    My '63 FI has a close ratio 4 speed and a 3.70:1 rear end.
    I don't know of all the available combinations but I heard you could even get a 3.08 on an FI car by special order.
      According to the NCRS Corvette Spec Guide, when a '63 was L84 equipped (FI) the only 4-spd manual transmission offered was close ratio. The standard rear gear was 3.70 and all other posi-traction offerings were available. FI did not preclude option A31, power windows...
      • Sydney G.
        • February 1, 1994
        • 444
        Howard,
        Yes, you could have ordered power windows with FI.
        But, you could not have had power steering as an option with either the 340hp or FI engine in '63.
        Syd
        • Howard Cox
          Thanks for the responses guys.
          Well if a close ratio was all that was available with L84 then something stinks in Denmark and it ain't the cheese. Unless the main gear was changed from 27 to 25 teeth.
