'69 hood support - NCRS Discussion Boards
'69 hood support
  • Jeffrey S.
    • May 31, 1988
    • 1888
    '69 hood support
    Hello all- Does anybody know if the hood support was in place before or after the body was painted on '69's. I am trying to figure out if the hood support reinforcement and bolt were painted body color or if the plate was natural steel and the bolt black oxide or what. My original plate is bare shiny steel underneath but the body has been repainted without this in place and so I can't use paint or lack thereof underneath as a guide. Any help is appreciated.
    Jeff
    Re: '69 hood support
    Jeff -
    The hood support was installed on the Hard Trim Line, after Paint.
    • Jeffrey S.
      • May 31, 1988
      • 1888
      John:
      Thanks for the quick response. If it was put on after paint, then I assume that the plate was bare steel (since the underside of my original is bare, shiny; I painted the top surface with semi flat black) and the bolt was black phosphate or oxide as the other 2 lower support bolts are. Thanks for your help.
      Jeff
