67 radiator support fasteners - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    Me again
    I need a description of the 5/16 bolts connecting the fan shroud to the radiator support. Are they grade 2 or grade 5?
    I need the same information for the 5/16 bolts connecting the radiator support to the inner fenders.
    Any help is appreciated.
    Thank you.
    Randy
  • Rob A.
    • December 1, 1991
    • 2126
    Re: 67 radiator support fasteners
    Randy,
    Bolts on my '66 small block are original. Fan shroud to upper bracket is RSC, no lines. Bracket to radiator support bolts RSC with 6 lines. Support to inner fenders WB, no lines.
    • Randy R.
      • March 1, 1983
      • 477
      Rob,
      Thank you for the information. If I could impose on you, please let me know what the four bolts fastening the shroud to the radiator support look like.
      Thanks again,
      Randy
      • Rob A.
        • December 1, 1991
        • 2126
        Randy,
        Indented 1/2" hex head, captive washer, pointed tip, marked E with 3 lines, dark phosphate coated. I believe these to be original also.
        • Randy R.
          • March 1, 1983
          • 477
          Thank you very much. I have some of those.
          Randy
