889 DISTRIBUTOR - NCRS Discussion Boards
889 DISTRIBUTOR
+ More Options
Posts
  • Bruce B.
    • May 31, 1996
    • 2930
    889 DISTRIBUTOR
    MY EARLY 57 250HP FUEL CAR (#809) HAS A CORRECT 889 DISTRIBUTOR WITH THE 5360 FUEL UNIT.
    I HAVE BEEN TOLD THAT THERE ARE OR HAVE PROBLEMS WITH OIL NOT DRAINING OUT OF THE DISTRIBUTOR AND SUBSEQUENTLY FLOODING THE POINTS. I'VE ALSO BEEN TOLD THAT GM RECALLED THESE UNITS AND DID A "FIX" ON THEM.
    HOW CAN I TELL IF THIS UNIT HAS BEEN "FIXED".
    THANKS IN ADVANCE.
    BRUCE B.
  • John D.
    • December 1, 1979
    • 5507
    Re: 889 DISTRIBUTOR
    Hi Bruce, The difference between the 889 and '905's is basically the 25 cents o'ring between the top and bottom halves of the distributor. Make sure you are running a stock engine oil pump. Also make sure you use some no name engine oil with zinc in it. When GM says they recalled the distributor that must have meant they machined a groove for the o'rings. I had a friend-Frank Cichon who is no longer with us that had an 889 that was fixed this way. It was the only one I had ever seen like that. Take care, John
    • Joseph T.
      • April 30, 1976
      • 2074
      Re: 889 DISTRIBUTOR
      Bruce..#775 has an 889 distributor...unrestored...this car ran with a GM part numbered Sun Tach...as used on 56 NASCAR Chevies.
      I also have another January fuelie engine with a tach drive 889...
      Not sure if either one has any recall fix..I doubt it...as both were factory race engines.
      Joe
      • Bruce B.
        • May 31, 1996
        • 2930
        Re: 889 DISTRIBUTOR
        John;
        Thanks for the info.
        I missed seeing you at Knoxville, maybe we will run into each other at Sevierville, TN in October.
        Sincerely,
        Bruce B.
        • John D.
          • December 1, 1979
          • 5507
          Re: 889 DISTRIBUTOR
          Hi Bruce, Missed you too. No more long distance shows for me. Just going to the Carlisle shows. Hope you bought some nice rare parts at Knoxville. Good luck with the 889 distributor. They are really rare for sure. Lots of early 57 FI cars need that distributor and typically they have the replacement 905. John
