I have another question regarding the engine items for my 71 Lt-1.
I used Felpro gaskets for the intake manifold. I am sure these are not the same as was originally used when the car was built, but I have no idea what physical differences may exist between these and original gaskets.
There is quite a bit of excess gasket that can be seen near one of the middle runners on each side. Would the original gaskets have had similar excess or were they made differently in this area? Basically, I am wondering if I should consider cutting out some of the excess that can be seen around the intake on these.
The blue gasket being exposed as much as it is honestly does not look to appealing to me, so I am tempted to try to cut some of it out. I am guessing that the original did not have this and therefore, if I cut it out, mine might look more consistent with original also.
Any thoughts?
Any thoughts?
