C2 1965 SHP Oil Pan Clips - NCRS Discussion Boards
  • Paul G.
    • August 31, 2006
    • 66
    Hope you can help me with this as I was pretty good at cataloging all of the parts I disassembled except these. As I recall, I think they came off the right side oil pan for the harness or bat cable but I can't remember the exact placement. Any help you can lend would be greatly appreciated.
    Paul
  • Mike G.
    • January 1, 1991
    • 418
    Re: C2 1965 SHP Oil Pan Clips
    Paul: These hold your plug wires in place for the "V" shields to fit over them. To figure out which pan bolt to use, hold your V shield in position and the bolt selection is apparent.
    • Paul G.
      • August 31, 2006
      • 66
      Thanks Mike, do you happen to know if these were painted with the engine?
        • 43222
        Paul----
        Yes, they were.
        • Paul G.
          • August 31, 2006
          • 66
          Thank You *NM*
