fan clutch eliminator
At high engine RPM, the factory fan clutch allows the fan to spin slower than the engine. Using the eliminator forces the fan to turn at full engine speed - and takes more power. You may also want to check your stock fan with the current clutch at high RPM to make sure it's not bending the blades forward closer to the radiator. When I worked in the racing shop, I saw more than a few radiators that were attacked by the fan due to the clearance being taken up at high RPM.
Mark
Mark
