C1 Brake Fluid Flush - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    I'm replacing the master cylinder and 1 of the brake lines on my '62. It has DOT-5 (silicone) brake fluid. Might as well flush the system too, seeing that I'm there. How much fluid am I going to need?
  • Donald B.
    • May 31, 2004
    • 299
    Re: C1 Brake Fluid Flush
    A quart should be more than enough.
    • Wayne K.
      • December 1, 1999
      • 1030
      Chris,
      You probably know this but you didn't mention the replacement fluid. If it had DOT-5 you should stay with that and the master cylinder should also have been assembled using DOT-5.
      Wayne
