date coding criteria - NCRS Discussion Boards
  • matthew block
    hello everyone. i was curious what some of the closest dates on blocks, then engine build dates, then car build date were. i have seen so many in each end of the time table. i was looking at a car to buy and the block casting was only a month from the build date of the car. block november-car december. it is curious to me if the block and heads were cast a month before the assembly of the car that they could make it down the line so quick. can anyone shed some light on this. any examples that they own and is documented for sure? thanks everyone. the professional information on this site is always appreciated.
  • Harry Sadlock
    Re: date coding criteria
    Matthew,
    Block - April 6th, 63
    Engine Build - April 15th, 63
    Car Build - April 20th, 63
    Harry
    • Mike M.
      • May 31, 1974
      • 8389
      this one will confuse some folks: 66 vin 18057, body build march 22nd. engone case cast date jan 22 1966 with pad machine assembly date of march 23rd. its real. mike
      • Harry Sadlock
        Mike, works for me! But what is the car build date?
        • Tom H.
          • December 1, 1993
          • 3440
          My 63 coupe.
          Built Jan 24th.
          Engine cast Dec 6th 1962, Assembled Jan 3, 1963.
          Tom Hendricks
          Proud Member NCRS #23758
          NCM Founding Member # 1143
          • Mike E.
            • February 28, 1975
            • 5139
            Matthew, if you check the archives, you'll find numerous discussions regarding this. Also, on the CD that has all the past articles from the Corvette Restorer, there is an article that I did (the dating game revisited) that follows the dating of a large number of 62's--and you'll find that the dates are all over the map.
            • Jim R.
              • June 30, 2001
              • 643
              65 eng cast 6-14-65 assby 6-24-65 car built 7-14-65. jim
              JR
              • Philip C.
                • December 1, 1984
                • 1117
                Re: date coding criteria Mike AO Smith Car *NM*
                • Mike M.
                  • May 31, 1974
                  • 8389
                  phil: you got it. mike
                  • matthew block
                    Thank you all so much for the information. i was skeptical about the engine build date only a week and a half after the block cast date, then 2 weeks before the car assy date. but i guess this is very possible as it seems many of you have dates within a week or two apart between the three. also, it is possible that the dates from the heads, intake, etc, can be a few months earlier since they were shelf items? thanks again. this site, the knowledge, and the gearheads are truly top of the line.
                    matthew
                    • Joel Falk
                      Yes, that is entirely possible Matthew. See the JG for detailed info.
                      • matthew block
                        JG?
                          JG= Judging Guide *NM*
