69 shock ID labels - NCRS Discussion Boards
69 shock ID labels
  • Greg L.
    • March 1, 2006
    • 2291
    69 shock ID labels
    What would be the correct two letter lable codes for the front and rear shocks for a 69 with standard suspension?
    Thank you kindly.
    Greg Linton
    #45455
    • 43221
    Re: 69 shock ID labels
    Greg-----
    "VR"---front
    "VS"---rear
    • Greg L.
      • March 1, 2006
      • 2291
      Thanks Joe...that's what I was afraid of...
      Just last week I applied the decals that I got from paragon to my freshly painted shocks and just tonight noticed in my TIM&JG that they are wrong. I should have known better because this isn't the first time I've had issues with paragons parts!! Stupid ole me just stuck them on as per their packaging label...not much I can do now though.
      Any idea on how I can remove these junk labels without hurting the paint?
      Would you happen to know where I could find the correct ones?
      • Paul O.
        • August 31, 1990
        • 1716
        Greg send me a self address stamped return envelope and will mail you some that I made off my printer they are not perfect but the price is right. Paul
        Paul Oslansky
        684 Brandy Way
        Cincinnat, Ohio 45244 513-965-8009
        • Jim T.
          • March 1, 1993
          • 5351
          Can new labels be applied directly on top of your newly installed labels without being noticed? Generally WD-40 will loosen labels and bumper stickers.
          • Greg L.
            • March 1, 2006
            • 2291
            Thanks a bunch Paul, I'll do that!
            Jim I'm not sure what WD-40 would do to the paint because I think the paint is still to fresh and it might come off too. As long as Paul's lables are the same size or even a tad larger than the wrong ones that were sold to me, placing them over top just might do the trick.
              The paint should 'laugh' at the WD-40 + take on a nice bright shine to boot!
                • 15601
                Generally alcohol will dissolve adhesive. I doubt alcohol -- in the form of the commonly available isopropyl -- would damage the paint, but testing a small less visible area (like on the rear inboard top) would be best for anything you try to use to remove the label.
                  • 11643
                  Paul,
                  Come on, it's not that hard to make them perfect.
                  Patrick
                  • Greg L.
                    • March 1, 2006
                    • 2291
                    Thanks guys. Actually the labels came off with no problems and the WD-40 removed all the remaining residue too.
