C1 TH350 and 283 - NCRS Discussion Boards
C1 TH350 and 283
  • Mark Radin
    C1 TH350 and 283
    My stock radiator does not have provisions to cool the transmission fluid. Is the solution to fit an aftermarket cooler? Comments and suggestions would be really appreciated.
    If you replied to my Carb question thanks - I took the concensus advice and am returning everything to stock.
    Mark (In England)
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 TH350 and 283
    Yes in front of the radiator a simple thing to do.
      • 43222
      Mark-----
      Using an external oil cooler is the ONLY option if you wish to retain a stock radiator and use the THM-350.
      • Verle R.
        • March 1, 1989
        • 1163
        Mark,
        If you are considering a turbo 350, you should also consider the 200R4 and get an overdrive to boot.
        Verle
        • Dick W.
          • 10483
          I second the 200R4. Good little transmission for a moderate weight and horsepower vehicle.
          Dick Whittington
