starter bolts - NCRS Discussion Boards
starter bolts
  • Bill S.
    • January 31, 2007
    • 396
    starter bolts
    how long are the bolts for a 1966 l72 starter?the bolts? i bought have about 1/4 inch of knurled surace exposed below threads when inserted into starter. the nose is a 3 hole cast iron piece.
    • 43221
    Re: starter bolts
    bill----
    The bolts should both be 3-5/8" long with the knurled shank.
    • Bill S.
      • January 31, 2007
      • 396
      joe, the shank?
      joe, i ordered the only ones that seemed the right length from paragon. i will have to measure. are they supposed to have some of the knural, about 1/4 inch follow the threads into the block? if you insert a bolt into the starter there is about 1/4 inch of knural exposed then the threads on the side that faces the block, thanks bill
        • 43221
        Re: joe, the shank?
        bill-----
        I'm not understanding what you're saying. However, the bolts are supposed to have the section of knurled shank as I think you're describing.
        • Bill S.
          • January 31, 2007
          • 396
          Re: joe, the shank is 3 5/8
          the length of the bolt is 3 5/8 as you stated. what i was tring to describe is that if you look at how much thread length there is to go into block there is thread and 1/4 inch of knural as oposed to all thread to the flat of the nose that meets the block. what i am getting at is if i bolt this up some knurl will follow the threads into the block when i draw it up. the nose has 720 on it and it is a "365" starter. also do i shim this?
          • Clem Z.
            • January 1, 2006
            • 9427
            the blocks are counterbored to fit the knurl
            so the bolt does not move around when cranking the engine
            • Bill S.
              • January 31, 2007
              • 396
              Re: thanks
              thats what i thought,thanks,bill
