C1 Radiator Core Supports - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    1. The upper fan shrouds on a '62 are attached to the radiator core support with 6 bolts (3 per side). Are there captive nuts welded to the inside of the core support to capture these bolts? Or, do you have to have exceptionally long and skinny fingers to put nuts on them?
    2. What's the difference(s) between 58-60 Corvette radiator core supports and the 61-62s?
  • Loren L.
    • April 30, 1976
    • 4104
    Check your AIM. *NM*
    • Christopher R.
      • March 31, 1975
      • 1599
      I Did. It's Not Clear.
      I did. It's not clear. I was hoping somebody was in that area of their car lately and could answer from memory.
      Thanks anyway.
      • Verle R.
        • March 1, 1989
        • 1163
        Re: C1 Radiator Core Supports
        Chris,
        I cannot answer specifically about a 62 but my 57 has captive (welded) nuts on the core support. You would need very long skinny fingers indeed to hold nuts for the bottom bolts.
        Verle
        • Christopher R.
          • March 31, 1975
          • 1599
          Thanks, Verle. I appreciate your response.
          Do you have 6 nuts? 3 per side? Are they those 4 sided ones?
