How to remove wiper arm from '58 - NCRS Discussion Boards
  • Steven B.
    • June 30, 2004
    • 256
    I need to remove my '58 wiper arms to get at the escutcheons and have unscrewed the nut that holds it tightly in place, but I'm not sure what to do next. I didn't want to just start pulling the arm if there was more to it. Thanks in advance. Steve
  • Roy B.
    • February 1, 1975
    • 7044
    Re: How to remove wiper arm from '58
    There is not anything to it , it must be stuck on the shaft , try using something to push on the wiper edge area to lift it up
    • Gary Bishop
      Roy Braatz 182 -- Friday, 16 March 2007, at 12:59 p.m.
      Just be careful how you do it. Make sure you pry the just the arm off. If you are not careful you could pull the center out of the transmission.(Don't ask as I did it on my `62 a few years ago.
      • Gerard Q.
        • February 1, 2000
        • 284
        Or you could use one of these.... *NM*
        • Mike M.
          • May 31, 1974
          • 8385
          Re: Or you could use one of these....
          agree with jerry. with the tool, removal is safe and quick. snap-on has them if you don't want to get it from long island. or you can make the tool using a 3/16" thick piece of strap metal. bend a three 90 degree angls in the strap using jerry's photo as template. mike
          • Tracy C.
            • July 31, 2003
            • 2739
            Make one? Just spend 3 bucks at Pep Boys for one in a package ya big tight azz.
            tc
            • Steven B.
              • June 30, 2004
              • 256
              Thanks All...Arms Came Off With Minor "Prying" *NM*
