Re: Roller Bearings - NCRS Discussion Boards
Re: Roller Bearings
    • 15674
    Re: Roller Bearings
    All disk brake Corvettes ('63 and '64 too) were equipped with tapered roller bearings at all four corners. If the front bearings are in good condition upon inspection after cleaning, I would suggest properly packing them with a high drop point grease designed for disk brakes and reusing them. If you take apart the rear spindle pack is is probably a good idea to replace the bearings as the cost of the bearing is small compared to the labor, however, a technician with experience and/or close adherance to shop manual procedures is required as a shim must be select fitted, the the pack torqued to the proper value, and final end play checked to be within spec.
