Re: Roller Bearings - NCRS Discussion Boards
Re: Roller Bearings
  • Jerry Clark
    Re: Roller Bearings
    Peter:
    I am not aware of the Timken Company makes a specific bearing for this application but in my experience they are currently the ONLY roller bearing worth using in any application.
    jerry
    • 43221
    Re: Roller Bearings
    Jerry-----
    I only use Timken bearings, myself. However, Delco bearings, most of which are now "Made in Japan", are a real quality piece. I've always been impressed with the quality of Japanese bearings. Plus, a lot of Timken bearings are now manufactured in "foreign" locales, Brazil being a common one.
    • Jerry Clark
      Re: Roller Bearings
      "You mention that you will be replacing your front ROTORS and go on to say that you currently have BALL BEARINGS. Those two things seem inconsistent. No Corvette with ball bearing type wheel bearings (53-62) ever used brake ROTORS and no Corvette with ROTORS (65-82) ever used BALL BEARING-type wheel bearings"
      Joe:
      I managed to read right past all this between the lines information, (discrepancy ), now I wonder what Peter is trying to do and what he has. I have no personal experience with the current production Delco bearings but obviously should check them out.
      Thanks for picking up on what I missed, need to quit doing this at night
      jer
      • Dale Pearman
        Re: Roller Bearings
        Varoom did, has, and IS.
        Varooom.
