Message Deleted by Poster
(Message Deleted by Poster)
Re: courtesy lights
The courtesy lights work by completing the ground when the doors are open etc. They always are have 12v available on the orange wire. The light switch also completes the ground when in that courtesy light position. I believe the switch depends on the cluster ground (#12 brown) connection for ground.
Do the instrument lights etc work? If not, check to insure that the ground is connected. You can also run a jumper from the metal of the body cage to the instrument cluster and see if the lights work. If not, then you have a problem with the switch or associated wiring (#20 white wire on switch)
Good Luck- Top
Re: courtesy lights
Remove the white #20 wire on the headlight switch. Using a jumper, connect that wire to a good ground (body cage metal) If courtesy lights work then switch is faulty. If not then that wire is open somewhere in the loom.- Top
Re: courtesy lights
Nick,
Please don't delete your original post just because you got your answer. It leaves all the rest of the following posts "hanging" and really does not help anything.
