1968 Electrical Problem - NCRS Discussion Boards
  • Terry B.
    • August 31, 1999
    • 607
    I need opinions before I tear into this problem. I am having an electrical problem with the following symptons. My dash lights will not come on, the tail lights no longer work, however the brake lights work fine. The turn signals also do not work. The head lights work fine along with the interior lights. Any ideas where to go first? Thanks for any help.
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
  • Stephen L.
    • May 31, 1984
    • 3159
    Re: 1968 Electrical Problem
    Check your fuses. Check your wiring diagram to determine what is common among these items and you've probably found your problem
    • Wayne W.
      • April 30, 1982
      • 3605
      Yep, they are on the same fuse.
      • David M.
        • September 30, 2004
        • 522
        Also verify all grounds, grounds, grounds, grounds. Grounds are your friends especially on a glass body!
