Blue Certification Label 1970 - NCRS Discussion Boards
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: 1970-I've got it for you!!!!
    It appears to me that ALL the repros on ebay are basically the same... as noted before, there may be some slight differences like color. All those must come from the same source, or someone is, er, "Zip-ping" off "knockoffs of the knockoff".
    I believe the geniesis of these labels is a not-so-good facsimile of the cert label illustration in the AIM, which is itself, not even close. I'm sure GM never considered needing to stamp "NOT TO SCALE" across an AIM illustration. Same old bs...expend all that time and energy making a bad repro, when a GOOD repro could have been made just as easily.
      • 15602
      • KEN BUTCHER
        #18
        Hi Chuck,
        Nothing is the same as the original, but the decal was the same size and color was good, it's just that the typing that is done of your vehicle info is a little thin compaired to the factory type setting. But if you need to replace it because someone forgot to take the time to peel it off and save it, or painted over it, what can you do? It may not pass judging, but it looks better than nothing.
        • Dick W.
          • 10483
          #19
          And most of the time, a replacement will get installation and configuration credit. Thus, condition points can be allotted.
          Dick Whittington
