Replacing C3 dash board - NCRS Discussion Boards
  • Ray Jackson
    I Just took my dash completly apart to fix stuff.
    I managed to remove the old cracked dash after removing the pillar trim
    but it was tough. To install the new dash with out damage would it be easyer if I removed the windshield or is there a trick I am missing?
    Ray
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Replacing C3 dash board
    Ray
    I would not remove the windshield. The dash pad fits tight but if you get it in position as far to the drivers side as you can and spray armorall as lube on the post and end of the dash on the paassengers side with a slight bend it should slip in with no damage. Pratice with your old dash to see how it goes in. If you bring the passenger end up from below where it needs to end up you should learn the trick.
    Lyle
    Lyle
