Intake/Carb Gasket for 1970 LS-5 - NCRS Discussion Boards
  • Tony H.
    • May 31, 1993
    • 537
    I am wondering what gasket goes to my intake/carb interface. I am away from my AIM and parts book and catalogs. I called a local Chevy dealer and they gave me a part number #3967470 but said they cannot get them anymore nor could they give me any dimensions. At NAPA, their carb rebuild kit comes with a thin gasket (1/16" inch or so)for the carb/intake interface while their individual gasket catalog gave them a part number which calls for another thin gasket only it's shaped like a holley carb gasket (obviously wrong). The 71-72 carb/intake gaskets are about 1/4" thick and of the correct Rochester shape. What did my car come with originally? What is the thickness (approx) for that gasket?
    Tony
    • 43221
    Re: Intake/Carb Gasket for 1970 LS-5
    Tony-----
    Well, your Chevy parts man is correct. The original gasket for your car (UNLESS your car happens to be an original California-delivered car with EEC) was GM #3967470 and this gasket is GM-discontinued. This gasket was a composition with steel core gasket approximately 3/32" thick. It had one large plenum opening which was sort of "hour-glass" shaped. There were no individual holes for the carb bores like the 68-69 Q-Jet gaskets. Although discontinued, this gasket is available in reproduction from, I expect, sources like Dr. Rebuild. He's usually got gaskets "covered", so I expect that he has this one.
    In the event that you have a 1970 which WAS equipped originally California-delivered and equipped with EEC, the gasket was originally GM #3969837. Currently, it is known as GM #10147945 and this gasket is still available. This gasket is an asseembly consisting of a gasket similar to the 3967470 attached to a relatively large, irregularly-shaped aluminum plate.
    • Tony H.
      • May 31, 1993
      • 537
      I did get the gasket you described with a metal core from NAPA but it was not listed in their catalog for my particular application.
      I do happen to have Dr Rebuild's catalog here at work (thought I left it at home) and it lists the gasket you mention as well as a "heat insulator" that resembles the approx. 1/4" thick gasket that I mentioned in my original post. The heat insulator is listed for 70-80 applications and is different from the CA cars. Should my non-CA emisions car also have a heat insulator or not?
      Tony
        • 43221
        Tony-----
        I do not think that the thick insulator was used for 1970 non-EEC cars. The insulator of which you speak was GM 3998919 which was replaced in SERVICE several years ago by GM #10069984. I believe that this insulator/gasket was first used on a production Corvette in 1971 or 1972. I'll check later and confirm when I can get to my references. This insulator can, however, be used on a 1970 Corvette with Q-Jet. In this usage, it would REPLACE the gasket that I previously described. You would also have to fabricate a new automatic choke rod to compensate for the 1/4" or so of additional thickness.
          • 43221
          Tony-----
          Just confirmed that the thick insulator type gasket was NOT used on 1970 Corvettes with Q-Jets and without EEC.
          • Roberto L.
            • January 1, 1998
            • 523
            Just for reference, the gasket mentioned by Joe for 70 California vettes is shown in the link below.
            Roberto, NCRS #30019, RMC
            California delivered carb gasket
            • Mike Andresen (27410)
              Roberto, You're making me jealous of the digital camera. A picture is worth a 1000 words.
              Cheers, Mike
              • Roberto L.
                • January 1, 1998
                • 523
                Hello Mike, I would love to have a digital camera but no way for now. I try to take good pictures and then scan them to use in the website and the like. But quality suffers with all those steps. Any way I will try to obtain detailed photos of original parts in my 70 (or other cars) for reference. All best, Roberto, NCRS #30019, RMC
                • Juliet P.
                  • June 30, 1999
                  • 349
                  Tony, if it turns out you need P/N 1014-9745, the Q-jet carb gasket that goes with the Calif emissions setup, give a holler before I put it on eBay. ~Juliet
                  Visit & Join the Online 1970 Corvette Registry!
                  2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
                  1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
                  1965 Coupe (Greg's project No Flight)
                  Gone but not forgotten:
                  1987 Yellow Convertible 199k mi.
                  2002 Yellow Convertible 100k mi.
                  2007 Atomic Orange Coupe 140k mi. RIP flood 2015
                  2007 Lemans Blue 6-Spd Coupe 34k mi.
