Delco Energizer R59S - NCRS Discussion Boards
  • Erv M.
    • February 21, 2007
    • 445
    Where is the best place to purchase a reproduction of the delco Energizer R59S? Also what point deduction will you receive if you install a correct reproduction battery versus putting something else in?
    Re: Delco Energizer R59S
    Flight scoring rules for battery are listed in your copy of the NCRS Judging Reference Manual, Section 4, Rule 2.
    • Erv M.
      • February 21, 2007
      • 445
      If I had that manual the question would not have been poise could you elaborate?
        The book is available for purchase...
        Section 4, Standard Deductions, Rule 2, Batteries:
        "No Originality Deduction: Original or original design reproduciton (indiscernible as installed) Delco as described in judging manual with, if applicable, appropriate plant and date stamp for the vehicle.
        Table of Originality Deductions:
        * Deduct 10%--Battery appearing as above but with no appropriate plant or date stamping, if applicable.
        * Deduct 30%--Reproductions differeing from original design and construction in minor detail.
        * Deduct 50%--Delco, correctly sized, service replacement with appropriate top or side post configuration.
        * Deduct 100%--Originality & Condition for others.
        • Erv M.
          • February 21, 2007
          • 445
          I did place an order for the manual a couple of days ago and if everything goes right will see it in a few weeks. Thank you for your assistance. Did not want to spend a great deal of money if there wasn't enough bang for the buck.
