Head gaskets - NCRS Discussion Boards
Head gaskets
  • Rex T.
    • December 1, 1984
    • 455
    Head gaskets
    What is the recommended head gasket for use on the new ZL-1 alum block with GM alum heads? Fel Pro Permatorque Blue, copper, etc??????? Compression will be under 10:1 and engine will be street driven, not abused.
    Rex
  • Clem Z.
    • January 1, 2006
    • 9427
    GM #12363414 or any composition gasket
    with a preflattened copper wire ring so not to brinnell the head surface.
      • 43219
      Re: Head gaskets
      Rex------
      My choice is Cometic Multi-Layer Steel (MLS). However, these are expensive (about $100/each). Otherwise, the gaskets that clem mentioned are fine. They're also known as Fel-Pro #1027. These are about $50/each.
