C1 - Tires for Wide Wheel Option - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    I've seen a lot about the wide wheel option for the C1 cars, but I've never seen anything about what kind of tires came with the wide wheels. Anyone know?
    Bob
    PS: After judging, I'd like to put radials on my '60. Anyone know what is the widest wheel and tire that will comfortably fit?
  • Mike E.
    • February 28, 1975
    • 5139
    Re: C1 - Tires for Wide Wheel Option
    6.70x15--generally blackwalls
    • Bob B.
      • March 1, 2003
      • 831
      MIke,
      Thanks for the response! But the regular size tires were 6.70 x 15. So what was the point of a wider wheel with the same width tire?
      Bob
      • Verle R.
        • March 1, 1989
        • 1163
        Bob,
        Look for 69 or 70 Camaro, Chevelle or Montecarlo 7x15 rally wheels.
        They should fit with 205-75 15 and maybe 215-15 75 15.
        If you want to run your stock hubcaps have someone mig the four little spots to hold them on. You may have to grind to shape to work well.
        As Duke recommends, a speed rated tire will be better/safer.
        Verle
          • 15692
          The 5.5" wheels were equipped with the same base 6.70-15 rayon-cord blackwall tires as the base wheels. Since the 5.5" wheels were designed for "competition" it was assumed the owner would install suitable tires.
          Back then purpose built racing tires had about the same dimensions as road tires.
          • Roy B.
            • February 1, 1975
            • 7044
            I have 215x15 radio tires on my 55 with the GM accessory wire wheels that are 5" wide and they work out great no problem here!
            • John N.
              • February 1, 1975
              • 451
              A exception to the blackwall rule was 57#4007 the earliest reported RPO579E car it was a factory delivery to Bill Howe. The car had whitewalls. The car was picked up at St Louis on 5-16 and driven to and raced at Cumberland 5-17,5-19 finishing in 3rd place. The car will be at Cumberland and BG Special Collection in June. The 1956 Wide Wheel Option cars were St Louis equipted with 670.15 Firestone Super Sports 170 tires, records indicate that 710.15s were available.
              Regards
