56-62 W-shield pillars, Still looking, difference? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 942
    I am still looking for someone that would know the difference between windshield pillars on 56 to 62 corvettes. I do not mean the door posts I understand them. The windshield pillars on my car appear to big in the area that the top of the door post meets. This I believe forces the top of the post out too far. I am putting in a new windshield and want to put the right posts in. Please Help!
  • Mike M.
    • May 31, 1974
    • 8396
    Re: 56-62 W-shield pillars, Still looking, differe
    i don't believe there is any differnce in the windshield post 56 thru 62. sounds like maladjustment problem. good luck, mike
    • William B.
      • April 30, 1975
      • 942
      I have looked at an origional 58 and also an origional 62 vette and in the area where the top of the door post hits the windshield pillar there is a definite difference. I supose no one is judging this, but I want to know when the changes were made. I like the windshield post with less casting in that area, it makes my door post fit the best.
      • Joseph C.
        Infrequent User
        • July 31, 1983
        • 11
        The early windshield posts, 1956-1958, were as follows: 3716385 LH, and 3716386 RH. The later design, used for 1959- 1962 Corvettes, changed to accommodate the new door post weather strip, were as follows: 3762679 LH, and 3762680 RH. Soon after introducing the later design post, between approximately October of 1959 to January of 1960, the parts people decided to eliminate the early part numbers, and they recommended using the later posts for replacements to earlier cars. The differences are mostly in the upper area of the recess where the door post nestles into the windshield post when the door is closed. If you study examples of both designs, you can see the differences. It is difficult to explain those changes in words.
        Joe Calcagno
        • Roy B.
          • February 1, 1975
          • 7044
          Joe! Great info ,the newest C1 I ever had was a 60, dint know about that - your the man! On the door post there were three different designs 56 then 57 to 59 early 60 and then mid 60 to 62 am I correct?? And all later part numbers used the later design # right??
          • William B.
            • April 30, 1975
            • 942
            Thank you, Joe, I did not think anyone could answer my question. Thanks again I printed out the numbers and I am going to check for part numbers tomorrow.
