C1 Window Regulators - NCRS Discussion Boards
  • Pierre J.
    • July 31, 2000
    • 193
    I need to have the window regulators in my '57 rebuild. Can anybody on this board recommend a vendors that provides such service?
    Pierre #34410
  • Paul M.
    • November 1, 1987
    • 142
    Re: C1 Window Regulators
    Grossmueller Classic Corvette in Phillipsburg, NJ
    • Roy B.
      • February 1, 1975
      • 7044
      Or e-bay under 55 to 57 Chevy and Pontiac Nomad there the same regulator
      • Terry D.
        • May 31, 1987
        • 2696
        Pierre
        I guess the first question would be what's wrong with it? Are the teeth on the gear missing, just loose or what? Most parts can be bought either repo or e-bay. Why not do it yourself?
        • Mike E.
          • February 28, 1975
          • 5139
          I think Roy may have led us all astray there--the window regulators are quite different on the Nomads--but the power window switches are the same. My 57 and 58 parts books both indicate that the Corvette regulators are Corvette only.
          • Roy B.
            • February 1, 1975
            • 7044
            Re: C1 Window Regulators "MIKE"
            Yes the nomads will work , regulator, power motor ,switch's, door wire shield and you could make the wiring harness work with a little work and even the door hinges if you needed them.
            • Paul M.
              • November 1, 1987
              • 142
              Roy aren't the window regulators the same in the conv. Hdtp and nomad????
              • Roy B.
                • February 1, 1975
                • 7044
                You could be right but I had Nomads along with these nasty Corvettes, I did own a 56 Chevy Vert that had the accessory rain sensor which few people knew what it was . I think your right!
