1963 VIN tag spot weld(s) - NCRS Discussion Boards
  • Al S.
    Infrequent User
    • March 31, 1975
    • 19
    The crossmember to which the VIN tag is spot welded seems to have grind marks under the spot welds.On one car the marks are horizontal (a coupe). The other marks are vertical(a convertible).
    Is this typical or is it a coinciderce?
  • Bill Lynch
    Re: 1963 VIN tag spot weld(s)
    Common. They would grind off a bit to get to clean metal so the spot welds would hold.
    • Mike M.
      • May 31, 1974
      • 8396
      i'd suspect that the horizontal vs vertical orientation was specific to the particular employee doing the grinding on any given day back then. regards, mike
      • Tracy C.
        • July 31, 2003
        • 2739
        Agree with Mikie #14 *NM*
