Why would someone..... (396 block VIN stamp) ? - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    I know you're all tired of seeing stamp pads , but here's an eBay 1965. Get your nose up to the screen on your monitor and see if you agree with me that the restorer has overstamped the existing but faint 5/32nds" height VIN derivative characters with a LARGER font.
  • Jim R.
    • June 30, 2001
    • 643
    Re: Why would someone..... (396 block VIN stamp) ?
    I agree wayne ,i would be careful if i were bidding that kind of money
    JR
    • Kevin M.
      • November 1, 2000
      • 1271
      Good eye, the other thing there all from the same set all the 5s match. Also the IF looks worked a little too.
      Kevin
      • Art A.
        • June 30, 1984
        • 834
        It say's......"THIS IS A CONCOURSE, FRAME OFF, RESTORATION TO EXACT FACTORY SPECS". Me thinks that they should look up the specs on the installation of the steering wheel............!!!!!
        AA
        • Chris Patrick
          Restamp. The I is crooked. The F is low. On the VIN, the spacing on 5 1 is different than the others. The others aren't right on, either, but a lot closer than the 5 1. Michael Hanson's notes about character spacing are right on, and I found it really makes a difference when you begin applying them.
          • Myron Sleeva
            Or simply pointed the front wheels straight ! *NM*
            • Mark S. Lovejoy
              Curiously the old VIN stamp seems to be the same numbers as the new stamp. At least that's what it looks like to me, but then I'm no 'spurt!
              • William L.
                • December 1, 1988
                • 944
                Could it be a bounce?
                Bill
                Bill Lacy
                1998 Indy Pacecar
                • Jim R.
                  • June 30, 2001
                  • 643
                  The book by David Burroughs, resto state of the art, 1965 blue on blue 396 roadster shows the assembly stamps with the numbers and IF very crooked, Also i think a lot of 396s were hand stamped.
                  JR
                    • 11648
                    That was my thought, too.
                    Without seeing it in person and measuring, I'd hold off on definitive judgment.
                    The suffix might be "off" and also factory applied. Al Grenning has numerous examples of the suffix letters being applied "out of line" with the other characters.
                    Patrick
                    • Loren L.
                      • April 30, 1976
                      • 4104
                      Wayne, he was simply tryig to make it
                      easier for those us "Old Farts" to read......
                      • Chuck S.
                        • April 1, 1992
                        • 4668
                        That was my first thought, but it appears the earlier set of VIN characters is actually shorter in height. If you could see the bottoms of the characters, both the early and later set would be pretty on the same line with the tops of the early characters falling short of the later characters. As someone else posted, the character spacing in the VIN set is also slightly irregular. Note that the re-stamper aligned the vertical stem of the "1s" because the difference there would be very obvious. If it were a "bounce", ALL of the characters (including the "1s") would be offset by the same amount.
                        • Bill W.
                          • March 1, 1980
                          • 2000
                          only the f was hand stamped . I thought it was a bounce until I looked at the 5 under the 8 .it looks like it was from 16555. Lots of wrong stuff for &125,000
                          • Billy Olson
                            Re: Wayne, he was simply tryig to make it
                            Sometimes hidden/underlying stamp pad evaluations are like seeing Mickey Mouse in the clouds or Jesus on a piece of toast. It is so very easy for our eyes to play tricks on us or to associate otherwise random variations and distributions with the "real" thing. At the very least it is entertaining forensics.
                            Billy
                            • Frank C.
                              • January 1, 1986
                              • 277
                              What I think I see is two different "6" stamps. The restamp "6" is differnt than the "6" under it.
