What is the proper size machine screw and correct head configuration for a early 57 Corvette gas tank cover? These are the 9 screws at the front edge of the cover. Are flat washers and/or split lock washers used also?
I believe the 9 rear and side screws use j-nuts and a sheet metal type phillips screw, please correct me if I am wrong.
Thanks.
Thanks.
