Need help with 087 and 202 coils - NCRS Discussion Boards
    • 15676
    I need the primary and secondary resistance values to help with a Restorer article I'm working on about the single point ignition system. I have the 091 specs in my '63 shop manual. For reference they are 1.02 to 1.13 ohms, primary and 8000-10.500 ohms secondary.
    I'm hoping that the 087 data is in the '64 Shop manual Supplement, and the 202 data should be in the '65 through at least '67 manuals. Thanks!
  • James F.
    • December 1, 1985
    • 596
    Re: Need help with 087 and 202 coils
    Duke, 087, primary 1.28 - 1.42, secondary 7200 - 9500. 202, primary 1.24 - 1.46, secondary 6500 - 9500. Regards
    • Dale Pearman
      What are the specs on 107 coils?
      Dale.
      • motorman
        i have no specs for 107 coil but i do have it for the 207 (transistor ignition) 75 deg F pri resistance .35/.55. sec resistance 75 deg F 8000/12500 ohms.
