Distributor Housing - NCRS Discussion Boards
Distributor Housing
  • Rob M.
    • June 30, 1999
    • 171
    Distributor Housing
    Is there any difference in the cast iron housing used in TI and point type distributors? I have a TI distributor (491 last 3 digits of PN) and the lower bearing is bad. Can I replace the housing (transferring all the TI parts) with one from a non-TI distributor? It goes into a 65 BB if that matters.
    My Project Pictures
    http://temp.corvetteforum.net/classics/l78vetteman/
    • 43222
    Re: Distributor Housing
    Rob-----
    While there are some minor differences between the tach drive housings, most that I know of are interchangeable. This includes interchangeability between points-type and FI. The exceptions are as follows:
    1) housings for dual point units with no provisions for vacuum control;
    2) housings for ball-bearing type units with TI and no provisions for vacuum control (these are SERVICE-only distributors; never used in PRODUCTION and are fairly rare);
    3) housings without "full round" annular oil groove at lower end of distributor.
