63 wiring harness - NCRS Discussion Boards
63 wiring harness
  • Steve D.
    • February 1, 2002
    • 990
    63 wiring harness
    The photo below shows an orange wire with a "j" connection that runs to the passenger side and is of the same length as the passenger side curtesy lamp connection. I can't identify it in the AIM wiring diagram. When I disconnected the old harness, I labeled all of the connections. This same connection was present on the old harness, but my label only had a question mark "?" . Can someone tell me what this connects to. (Non air car with heater and radio.)
    Steve
  • Dino L.
    • February 1, 1996
    • 694
    Glove box lamp switch *NM*
    Dino Lanno
    • Steve D.
      • February 1, 2002
      • 990
      Re: Glove box lamp switch
      Dino
      Thanks. I haven't installed the GB yet and I forgot all about it.
      Steve
      • Harry Sadlock
        Re: 63 wiring harness
        Steve, as soon as you connect the battery, that wire goes HOT. So place some tape over the end to avoid problem till the glove box goes in. I would think you would connect the battery to do a clock, radio, etc check prior to installing the glove box.
        Harry
        • Steve D.
          • February 1, 2002
          • 990
          Harry
          Thanks for the thought. I have had the battery connected numerous times, but have just been lucky that nothing happened. I'll tpe it up.
          Steve
