powerglide bellcrank--1957 - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8385
    when i removed the powerglide from my ole 57 near 40 years ago, i didn't label the bellcrank. over the years i've accumulated a half dozen bell cranks. however, there are two styles laying on the workbench and i can't determine, from the parts books, which style is the original off the 57 vette. the bellcrank brackets come in two styles, A being a non-gusseted critter and B style being gusseted. can someone with an original bellcrank look and see which style i need to use. thanks, mike
  • Verle R.
    • March 1, 1989
    • 1163
    Re: powerglide bellcrank--1957
    57 powerglide shifter levers
    • Verle R.
      • March 1, 1989
      • 1163
      kickdown lever
      • Verle R.
        • March 1, 1989
        • 1163
        Mike,
        Are you referring to the kickdown linkage bellcrank on the intake manifold?
        Verle
        • Mike M.
          • May 31, 1974
          • 8385
          thanks for great pictures, verle. the powerglide i'm dealing with will be behind a 250hp engine so i don't believe there is a bellcrank mounted on the FI base plate. go to the AIM RPO 579, sheet 3. what i'd like to see is a picture of Item B in that illustration.also, is the length of Item C 13 5/8" OL. Is Item E 7 7/16" in length?thanks again, mike
          • Edward M.
            • November 1, 1985
            • 1922
            Mike;
            I wish I could offer more help than this, but, the only suggestion I have is to track down the current owner of Brent Ferguson's old 57 250hp automatic car. Also, perhaps his wife may still have the pictures of the restoration. I recall seeing the completed chassis, with drivetrain installed, at Cypress Gardens one year.
            Any possibility that pictures of that chassis were taken for one of the publications that usually covered those events (Vette Vues, The Restorer, etc.)
            • Verle R.
              • March 1, 1989
              • 1163
              Mike,
              It will be Tuesday before I can get to a set of linkage like that. I'll measure it and let you know.
              Maybe someone else can provide the answer before then.
              Verle
              • Mike M.
                • May 31, 1974
                • 8385
                no hurry. thanks verle, mike
                • Verle R.
                  • March 1, 1989
                  • 1163
                  Mike,
                  I could not find the upper link.
                  Have pictures of the bellcrank and lower link.
                  Verle
                  • Verle R.
                    • March 1, 1989
                    • 1163
                    Re: powerglide bellcrank--1957 *NM*
                    • Verle R.
                      • March 1, 1989
                      • 1163
                      Took this off a 57 last year.
                      The lower link is 8 1/4" long end to end.
                      Verle
                      • Verle R.
                        • March 1, 1989
                        • 1163
                        Mike,
                        After going back over your earlier posts and looking at your question, I think 13 5/8" would be too long for the upper link (item E in the AIM picture)for an FI. That sounds more like a link for a 220 HP single 4-bbl engine.
                        I think the bellcrank and lower link is the same, just the upper link is different.
                        I hope someone else will speak up about this. I know there is some real expertise following this.
                        Verle
                        • Roy B.
                          • February 1, 1975
                          • 7044
                          (Message Deleted by Poster)
                          • Roy B.
                            • February 1, 1975
                            • 7044
                            (BIG MISTAKE that I said) the bellcrank for the 57 FI dont look anything like what you show, the bellcrank you show is used for one or two Carb set up for a PG.
                            • Mike M.
                              • May 31, 1974
                              • 8385
                              roy: lets see, in picture form, what you think the 57 PG FI bellcrank should look like. i see no reason why the carb bellcrank would need to be configured any differently than the FI bellcrank. what ya think roy? mike
