71 seat frames - NCRS Discussion Boards
71 seat frames
+ More Options
Posts
  • john peeling
    71 seat frames
    Hello again , I have some rust on my seat frames ( not much) I want to just touch up frames and noticed that krylon glossy black or krylon semi flat black are not good matches any suggestions . Also how durable is a spray can finish?
    • 43232
    Re: 71 seat frames
    John------
    I would not be too concerned regarding paint match for the seat frames. These are, essentially, unseen. I would use a gloss black on them and let it go at that. In fact, I'd recommend painting everything rather than just "touching up". While you may have been lucky as far as corrosion goes, seat frames definitely have this problem. So, I'd apply a full coat or two of a rust-inhibiting, gloss black like Rustoleum. For an application like the seat frames, I think that you'll find that a good quality paint like Rustoleum in a spray can is going to be as durable as you're ever going to need.
