67 Teal Replacement Carpet - NCRS Discussion Boards
  • Douglas L.
    • August 31, 2003
    • 301
    I'm replacing Teal carpeting in a 67 coupe. Whose teal carpet is closest to original in color and thickness?
    Knoch
    ACC - Regular Teal
    ACC - Dark Teal
    So far, I am leaning toward ACC - Dark Teal. Can any judges give me a perspective on this?
    Doug Lee
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 67 Teal Replacement Carpet
    None of them are even close to the original teal. Started out with lighter teal from ACC. I used inking dye and dilute with alcohol and applied with a rag little at a time to get correct color. This took hours...........
    Do this inking with pinch welting removed. Also restored and sew on original pinch welting as replacements suck.
    • Douglas L.
      • August 31, 2003
      • 301
      Gene,
      I knew there had to be someone else out there with the same frustration I'm having.
      I was told by one vendor that there may have been two different Teals used in 67. I don't know how that coule be substantiated.
      Here are a couple of pics - one showing original faded carpet versus unfaded around the jack cover. Look closely and you will also a small piece of the Knoch Teal laying on the front side of the jack compartment as a comparison.
      And this picture is the best I could do showing(in natural light) the different shades of the three teals found so far.
      I am kind of leaning toward the dark teal because in natural light, it looks good.
      Thanks for your comments on your solution.
      Doug Lee
