Advice re gas - NCRS Discussion Boards
Advice re gas
  • Richard M.
    Infrequent User
    • October 22, 2006
    • 28
    Advice re gas
    What gas should I use for a 63 327/340 engine? Thanks to all that respond.
  • Jack H.
    • April 1, 1990
    • 9906
    Re: Advice re gas
    Top quality, premium, pump gas should do the trick for you. In some sections of the nation, you can get 94 octane (R+M/2) and in other places the max premium blend is rated lower in octane. Out here in the Rocky Mtn's, our max pump blend runs 92 octane, but at our altitude it isn't a major factor...
    • Jacob A.
      • December 1, 2003
      • 237
      Re: Advice re gas
      I have to add 1 bottle of 108 octane to every 5-7 gallons of gas in my big block to keep her from backfiring? Sounds stupid... but it works
      She was kind of built for speed though!
      NCRS brothers.....don't fear the hot rod!!! The correct #'s matching L-71/435 block is going back in as soon as I am finished building it....
      • Jack H.
        • April 1, 1990
        • 9906
        Re: Advice re gas
        My factory stock '65 L78 runs just fine on pump gas...
