'66 grille upper tab attachment screw - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Is the center, upper grille tab attaching screw a round head phillips like used on the lower tab, or an indented hex head like the one attaching the other end of the support rod?
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: '66 grille upper tab attachment screw
    Check your AIM. I believe it will show the same part number for all the fastners that hold the grille in place. A different part number is listed for the upper bracket to header brace
    • Bryan L.
      • June 30, 1998
      • 397
      Its the round head phillips like you suspected. There are 6 total holding the grill in.
      BL
