C-1 Power Window Switches - NCRS Discussion Boards
+ More Options
Posts
  • Richard T.
    • February 1, 1979
    • 858
    I'm trying to find out how to dissassemble C-1 power window switches. I want to remove the bezal from the drivers side switch for re plating but don't want to break anything in the process. Any help appreciated. Rich
  • Las K.
    • July 31, 2006
    • 96
    Re: C-1 Power Window Switches
    Rich,
    How far have you gone on the removal? Have you removed the door panel, the backing clips from the switch, the harness from the switch?
    • Richard T.
      • February 1, 1979
      • 858
      The switches are removed from the panel. I want to seperate the bezal from the switch.
      • Roy B.
        • February 1, 1975
        • 7044
        You see those little spring clips ,now look at the bezel (side) housing and see the little holes , the clips have a tang holding them in ,push the tang inward as you pull the clips up and out later re bend the tags out so they will again catch the housing bezel .
        • Richard T.
          • February 1, 1979
          • 858
          Thanks Roy, I'll give it a try. Rich
