Diff. between orig.&repo A-arm bushings? C2 - NCRS Discussion Boards
  • Stan E.
    • April 30, 1991
    • 383
    What is the difference between orignal and reproduction 63 control arm bushings? Thanks stan#19259
  • Jim R.
    • June 30, 2001
    • 643
    Re: Diff. between orig.&repo A-arm bushings? C2
    I think it is the length of the steel torwards the end it should be about 1/4 inch shorter.
    JR
      • 43208
      Stan and jim-----
      It is as Jim describes but for the UPPER bushings. All LOWER bushings that I've seen are of the original configuration which was used from 1963 through 1982.
      Reproductions of the original upper bushings used for 1963-72 Corvettes are now easily available for about 10 bucks, each.
