C2 Side Mirror? - NCRS Discussion Boards
C2 Side Mirror?
  • M W.
    • July 31, 2001
    • 835
    C2 Side Mirror?
    Hi all,
    Is there a way to tighten my 63 drivers door mirror or is it at the mercy of the wind at higher speeds? Are all inside and outside mirrors date coded? If so is it visible at close inspection?
    Craig Willetts
    #36551
  • Bob R.
    • June 30, 2002
    • 1595
    Re: C2 Side Mirror?
    There is a way to correct the problem it has been discussed several times. Try doiing a search in the archives.
    • Jim R.
      • June 30, 2001
      • 643
      Re: C2 Side Mirror?
      all outside mirrors are date coded ,and only standard mirrors are dated on the inside. yes you can tighten your mirror all you have to do is remove the mirror glass retainer ,pull out the glass and i think there is a adjusting screw inside its been a while since ive had one apart.good luck. jim
