C2 GM Front Spring P/N #3851100...Joe Lucia? - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2660
    Joe,
    Could you please tell me what application this front spring part number 3851100 is correct for?
    James West
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: C2 GM Front Spring P/N #3851100...Joe Lucia?
    I believe these are correct for all 64 to 67 small block Corvettes. The pic below is the correct OEM configuration. I believe the springs sold under this part number these days are different.
    • George C.
      • November 1, 2001
      • 568
      I am not Joe, but that is the correct number for the 64 - 67 variable rate spring. This is for all small block applications.
      George
      #36908
        • 43240
        George, tracy, and James-----
        GM #3851100 is the part number for the front coil spring used for most 1964-67 Corvette small blocks, except 66-67 with C-60 and all with F-40 . It was also used for 1965 big blocks and some 1966 big blocks.
        It is no longer available from GM, having been discontinued several years ago.
