What kind of lube should be used on window regulator gears? Thanks, Jimmy
C - 1 Window Regulator Lube
Re: C - 1 Window Regulator Lube
Jimmy,
I used a NAPA silicone based stuff called Sil-Glyde (part #765-1351) It comes in a 4 oz. squeeze tube. It says its "non-melting, non freezing, non-gumming and weatherproof". It's nearly clear and the consistancy of axle grease. It's working great on my regulators!
Brad- Top
