delco solenoid - NCRS Discussion Boards
delco solenoid
  • Mike M.
    • May 31, 1974
    • 8382
    delco solenoid
    can't find part #1114458 application. its not voltage stamped. wondering if 12 or 24 volt solenoid. thanks mike
  • William C.
    • May 31, 1975
    • 6037
    Re: delco solenoid
    12 volt Mikie, GM cars & trucks. '56-81 some ford trucks, AMC, IHC, etc.
    Bill Clupper #618
    • Clem Z.
      • January 1, 2006
      • 9427
      Re: delco solenoid
      it is a high temp solenoid for motorhomes and boat engines. also do what this, The small terminal on the solenoid should have a Belleville (pn2030900)or star spring washer under the nut. A conventional spring washer only provides tension at one spot, while the others provide 360 degree pressure. This will compensate for the heat-related growth in length of the stud.
      • Mike M.
        • May 31, 1974
        • 8382
        Re: delco solenoid
        thanks clup and clem. mike
