CAD Plating in Northern Virginia - NCRS Discussion Boards
  • Stephen Rosenthal
    Can anyone recommend a reliable company in Northern Virginia that does CAD plating?
    Steve
  • Donald T.
    • September 30, 2002
    • 1319
    Re: CAD Plating in Northern Virginia
    Stephen,
    I don't know if a source for cad plating in that area. However, you may want to consider zinc plating instead. Although GM specs called for either zinc or cad, most if not all parts were actually zinc plated. It will be much easier to find someone to do zinc plating as opposed to cad. You can even do it yourself if so inclined. There's lots of info in the arhives as well.
    • Bryan L.
      • June 30, 1998
      • 397
      Not in your area but Steve Gregori in Calif does all kinds of plating. His website is www.detailplating.com He has done plating on a 69 Z/28 Camaro and 2 Corvettes for me and his work is really nice. He's also an NCRS member and advertises in Driveline.
      BL
      • Stephen Rosenthal
        Good point - I'll check the archives. In the meantime does anyone recommend a "Zinc" plating company in Northern VA?
        Thanks again,
        Steve
