1970 Rear Valence - back side of fiberglass - NCRS Discussion Boards
  • Stephen B.
    • April 1, 1988
    • 876
    When purchasing NOS fiberglass for a 1970, isn't the molded color different as compared to the original? The outside of the rear valence is painted body color; however, isn't the back of the fiberglass left raw? Thanks, Bunky
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: 1970 Rear Valence - back side of fiberglass
    Color should be dark charcoal gray. I believe some later NOS fiberglass may be the Gennite material; kind of light to medium gray.
    For painting, the exhaust panel was loosely hung on the car with two bolts...the back side should be natural fiberglass.
    • Stephen B.
      • April 1, 1988
      • 876
      Thanks Chuck, That's what I thought it to be the case.
      • Warren L.
        • February 1, 1990
        • 85
        There are pictures I believe in the 70 Registry of grease pencil markings and undersides of some cars back there if I remember correctly. I know I sent a photo of that area and marked on mine maybe in the license area. May be worth a look I should check first but it used to be there.
        Warren
        • Chuck S.
          • April 1, 1992
          • 4668
          Warren, yours should have looked something like mine (two pictures; the bottom picture shows the marking detail).
          I was looking through Dobbins' Fact Book of 1968-1972 Stingray, and I happened to see his picture of a 70 exhaust panel (Third Edition, page 256). I made an interesting observation: the handwriting of the date marks was the exact same as on mine, i.e. the 6 is made with an almost non-existenent loop and the little tail on the loop end.
          There seems to be no system to the location of the mark; mine is marked on the extreme left end, and his is marked on the right end. I expect that exhaust panel may have been from a late car like mine.
          • Stephen B.
            • April 1, 1988
            • 876
            Thanks guys.
