Regrinding a Camshaft????? - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    #46
    not all chevy cam bearing both BBC and SBC
    have the same outside diameter. #2 and #5 both have the same outside diameter and can be interchanged EXCEPT in 65/66 BBC. some also have different oiling holes for the front bearing to get more oil to the thrust surface of the cam gear.
    • Clem Z.
      • January 1, 2006
      • 9427
      #47
      you MUST used a grooved cam in any 65/66
      block along with the rear cam bearing with 3 holes to get oil to the lifters
      • Eugene B.
        • May 31, 1988
        • 710
        #48
        Re: you MUST used a grooved cam in any 65/66
        Clem,
        I read the original posts on this subject and they got me to thinking about my replacement camshaft. After reading your post this morning, I went to the garage to look at my parts archive.
        My original '65, 250HP camshaft does not have a groove around the back cam bearing surface. What am I missing or not understanding about this post.
        Best regards,
        Gene
        • Clem Z.
          • January 1, 2006
          • 9427
          #49
          the grooved cam only applies to big blocks *NM*
